06-07 injector failure, TSB vs alternative method of repair research article
Old Apr 17, 2026 | 01:03 PM
  #41
LG7rumble's Avatar
Originally Posted by Rocket Surgeon!
...I found a different stock injector to try: 12582219 a 25lb injector from a 05-10 cobalt or 07-10 G5 ecotec?
https://injector-rehab.com/knowledge-base/flow-rates/
This seems much more promising.
I don't mean to resurrect an older thread (and it wouldn't have been so old if I had had a chance to do this work on my car a couple years ago), but I'm seeing conflicting specs for those 12582219 injectors
Injector-Rehab has them listed as 25lb, but they're listed as 21lb here;
https://www.injectorplanet.com/produ...otors-12582219
I know you've had measured success with them, so perhaps Injectorplanet has incorrect info?
Either way, I've got four en route for my 2.2 2006 that I'm planning to throw in soon and hope for the best
I really appreciate the investigation, I'm on board for this kind of stuff.
Car's in the shop right now for what I thought would be a front wheel bearing, but might actually be the diff in the transmission... at which point I may cut my losses and just have to get a new car, considering the other work this thing needs and the work I've already put into it.
Old Apr 17, 2026 | 01:46 PM
  #42
AC Delco P/N 2172907 or GM P/N 12606110
are what I see listed for a 2.2 2006
hhr_2009
Aug 30, 2020 08:24 PM
LEN
May 26, 2014 04:51 PM
mmgrim
Feb 11, 2014 07:46 PM
HHRDK
2.2L Performance Tech
May 30, 2008 10:12 PM
hookupny
Jun 11, 2007 11:09 PM
