2006 2.2 HHR....belt or chain..??
Old Sep 20, 2011 | 11:14 AM
alexrckid's Avatar
anyone know if the 2006 2.2 HHR has a timing belt or a timing chain...?? thanks..
Old Sep 20, 2011 | 11:19 AM
pitbull76's Avatar
Chain
Old Sep 20, 2011 | 11:23 AM
to the forum alexrckid!
And yes its a timing chain, shouldn't require service for the life of the vehicle according to GM.
Old Sep 20, 2011 | 01:18 PM
alexrckid's Avatar
thanks................good to be aboard.....
Old Sep 20, 2011 | 02:49 PM
JoeR's Avatar
Actually, DUAL chains!
Sounds racy, huh?
Both are driven off the crank. The "rear" chain drives both balance shafts and the water pump. The "front" drives both cams.
Old Sep 20, 2011 | 03:32 PM
nacademus's Avatar
Chains last longer than belts, however, tensioners tend to wear out in some cases.
Old Sep 21, 2011 | 07:53 PM
alexrckid's Avatar
thanks for all the good info.............
Old Apr 19, 2012 | 05:33 PM
129k2006's Avatar
Anybody know when and if the tensioners need to be replaced? I got 177k on my 06. A buddy keeps telling my i should replace the guides. Any idea?
Old Apr 19, 2012 | 10:55 PM
Well at 177k, I'd replace them if you're opening up the engine, or if the chain is noisy...and at that point changing the tensioner is a good idea along with a fresh chain.
There isn't a set service interval on the chain, some are still going strong at well over 300k, and others have pooped out as soon as 125k. Its all down to maintenance, the engines that seem to come up short have been run for extended mileages between oil changes.
johnco
Maintenance and Upkeep
May 27, 2014 03:09 PM
TEKNOnaut
Jul 13, 2012 06:56 AM
sarroj
Feb 21, 2012 06:35 PM
geg
2.4L Performance Tech
Apr 27, 2010 11:56 AM
wagoneer
Apr 9, 2009 11:44 PM
