ambient air temp sensor..2006 hhr lt
Old Nov 9, 2012 | 05:01 PM
alexrckid's Avatar
anyone have experience changing out the sensor..?? exactly, how is it attached..??? any idea how you get to the ambient air temp sensor..?? it's located behind the headlight, in the fender, on the right side...do i have to pull the inner fender liner..?? thanks.
Old Nov 10, 2012 | 09:18 PM
alexrckid's Avatar
ok...here goes.....picked up a new ambient air sensor from autozone.
http://shop.advanceautoparts.com/web...rature+sensor#
replaced the stocker only because i questioned some of the outside air readings that i was getting and those readings seemed to lag. anyway.....was a piece of cake to swap out. jacked the front. with thw wheels cut to the right, was able to partially remove the right inner wheel well liner more than enough to get to the sensor which was mounted with a exterior body fastener. now. with the new sensor, get what seems like a much more accurate reading as well as a quick temp change while driving...and, it now matches the 10 or so banks in my area that have temps displayed...............
Old Nov 10, 2012 | 10:27 PM
oneton's Avatar
You must be the only person that the air temp reads the same as any other temp reading...
Old Nov 11, 2012 | 12:20 AM
alexrckid's Avatar
only lucky one, i guess....
Brwbier
Oct 5, 2017 11:46 AM
shaneslife
Aug 28, 2015 03:01 AM
ald
Aug 15, 2015 12:47 AM
Scorangehhr
Jan 13, 2015 04:56 PM
Turbo_Tomater
Mar 27, 2013 02:26 PM
