brake question yet again
Old Aug 28, 2018 | 05:07 PM
Here’s that guy, thought he has it made by changing the steering rack, well read this thread.
https://www.chevyhhr.net/forums/how-...ng-rack-58948/
Old Aug 29, 2018 | 08:18 PM
87z16's Avatar
ah asking the experienced!!! man you went back and forth with this and covered the field!! THANK YOU!!!
still waiting on my parts. ordered all 3. with my luck replace one, then in a month the next and causes the new mount i just replaced to go. im going to do them all at once. well when this humidity breaks!!!!
also going to add more grease to the contact points on the rear brakes. hate the squeak!!
Old Sep 2, 2018 | 08:09 AM
87z16's Avatar
ok, got my mounts in the mail yesterday. got the top passenger side in without a hitch. then got the drivers side out. all was looking good. got the 3 bolt started then went to get the last connection to the block and the bolt wouldnt start. ok after a bit took it out. the bolt was too big. they sent me the wrong mounts. it said the parts would fit my car. guess they sent me for a 2.0 or 2.2. then i had to struggle too get in the old part took me quite awhile. i also installed a new engine airfilter.
looking to desqueak the brakes today!!
Old Sep 2, 2018 | 12:59 PM
Cat Man HHR's Avatar
PM sent
Old Sep 2, 2018 | 06:48 PM
87z16's Avatar
see the holes closest together? diameter difference then the bolt standing on end. i think you can tell the old one! but it seems in ok condition but im sure it will break soon now that the other has been replaced.
Old Sep 3, 2018 | 04:33 AM
What is the difference in bolt hole diameter between the two ?
Old Sep 3, 2018 | 04:59 AM
Since it appears to be the correct mount, why not just drill out the mount hole a little bigger ?
Old Sep 3, 2018 | 06:10 AM
George it might be the other way around. The newer one has larger bolt holes than the OEM.
Old Sep 3, 2018 | 06:56 AM
He said the old bolt from the old mount was too big. That would mean the new mount hole was too small.
(The picture seems to show a smaller hole on the new mount)
Anyhow. Both mounts seem to have the same amount of metal or "meat" on that tab. I still say drill it out. Easier than the hassle of returning it for another.
Old Sep 3, 2018 | 08:01 AM
Originally Posted by 87z16
the bolt wouldnt start. ok after a bit took it out. the bolt was too big. they sent me the wrong mounts. !
Ok as they say "My Bad". Yes I agree, just drill out the hole on that one.
