Cleaning all l the grounds
Old Jun 3, 2022 | 07:35 PM
hurst2001's Avatar
First time I’m doing this so my question is on the drivers fender there a ground that nut is rusted that grounds to body can I use penetrating oil on it to loosing it up ? Should I unhooked the battery before cleaning up any grounds ? So there is one on the core support and on top off the transmission any more? Thanks
Old Jun 3, 2022 | 08:21 PM
Pentrating oil is OK, no need to worry about the battery when playing with grounds.
https://www.chevyhhr.net/forums/how-...cations-56504/
Old Jun 3, 2022 | 09:14 PM
Just make sure the wrench doesn’t touch any positive terminals, like the starter or alternator or the fuse box lug.
I use a plastic handle stainless steel bristled brush to clean the ground studs and wires
Old Jun 3, 2022 | 09:58 PM
greg8453's Avatar
You would be best to get some ground strap and cable and do new ones to the body at fender/rad support, firewall, frame rail and rear panels.
Fedves86
Sep 27, 2021 04:37 AM
hurst2001
Maintenance and Upkeep
7
Jan 19, 2020 11:33 PM
Silverfox
Mar 12, 2018 10:26 AM
seattlekev
Apr 24, 2016 02:59 PM
andyb
Oct 13, 2015 06:10 PM
