throttle body cleaning
Old Dec 19, 2013 | 10:27 AM
hurst2001's Avatar
Hello just like to know the best way to clean it ? I know to use throttle body cleaner but do use a tooth brush or rag ? also can you move the butter fly with out any problems ? or what are the do and do not ? thanks
Old Dec 19, 2013 | 12:20 PM
Use a lint free cloth, no toothbrushes, and let the Throttle Body Cleaner do most of the work. Once the cleaner has dissolved the carbon gunk/goop, carefully wipe up the excess cleaner and deposits.
Take great care in moving the throttle butterfly manually, do it gently and slowly.
Old Dec 19, 2013 | 01:50 PM
and DO Not spray the MAF sensor with TB cleaner use MAF cleaner. I was tempted but, I refrained!!
Old Dec 19, 2013 | 07:04 PM
hurst2001's Avatar
Ok but you can move the butterfly say like half way to clean with out messing the idol up ? just being cautious thanks
Old Dec 19, 2013 | 07:32 PM
You could pull the fuel pump fuse (#13) and the ECM fuse (#41) in the underhood fuse box, then have a helper hold the gas pedal to the floor to initiate the "Clear Flood" mode while cranking the engine.(The same procedure you'd use when running a compression check)
That would pop the throttle butterfly wide open without your physical intervention. But it's probably not necessary to get that radical, unless the throttle body is really carbon caked.
Gentle handling of the butterfly will usually not result in any post cleaning issues, it's when folks take their fingers or a screwdriver and just snap that sucker open, then you hear the tales or erratic idling.
Old Dec 19, 2013 | 08:26 PM
hurst2001's Avatar
Ok thanks that what I needed to know
Old Jan 19, 2020 | 08:22 PM
Pedro J Saade's Avatar
don't know what to agree or disagree
I would agree with you if I did not take my throttle body apart and see that they're it's no damage in the inside internally or any stripping
Old Jan 19, 2020 | 11:33 PM
that's a 7 (seven) year old thread - that 843de is no longer around as noted in his postings profile. .
BeanWagon
Jan 20, 2020 09:42 AM
guille2228
Jan 15, 2015 05:51 PM
irmandy2
"How To" Tutorial Library
7
Mar 27, 2014 11:28 PM
Gsus
Jan 31, 2013 03:37 PM
intofocuszx3
2.2L Performance Tech
18
Feb 2, 2009 04:50 PM
