Did Headlight Restore
Old Mar 26, 2022 | 07:13 AM
  #31
Chemical reactions to the plastic lens.
Old Mar 26, 2022 | 10:27 AM
  #32
Vinnybagodoughnuts's Avatar
The cost of a decent clear coat is prohibitive.You might as well buy a new set of headlights.I am all for using a good clearcoat but my point is it is not necessary if easy once a month maintenance is done by spraying a good UV protectant.Like I stated even if you forget or neglect them it takes a few minutes to buff them back out provided you don't let them get really bad.I have kept my headlights clear for many years doing this.I just finished removing a failing clearcoat on a friends car headlights and it was a pita.He was broke so I donated my time but if I had to do it again I would have bought him new headlights....
Old Mar 26, 2022 | 12:32 PM
  #33
PulpFriction's Avatar
There’s that. Polycarbonate is notoriously sensitive to rapid attack by many chemicals. A urethane would not likely attack it once cured, but when it first goes on wet…
I wonder what’s on a brand new headlight. Doubt if it’s bare polycarbonate.
Old Mar 27, 2022 | 01:24 PM
  #34
DangerBoy's Avatar
Yes, the manufacturers put a PU or other type clearcoat on headlamp lenses to protect the polycarbonate from UV and chemicals, etc.
Originally Posted by Vinnybagodoughnuts
The cost of a decent clear coat is prohibitive.You might as well buy a new set of headlights.I am all for using a good clearcoat but my point is it is not necessary if easy once a month maintenance is done by spraying a good UV protectant.Like I stated even if you forget or neglect them it takes a few minutes to buff them back out provided you don't let them get really bad.I have kept my headlights clear for many years doing this.I just finished removing a failing clearcoat on a friends car headlights and it was a pita. He was broke so I donated my time but if I had to do it again I would have bought him new headlights....
This 2K clear coat product This 2K clear coat product
is reasonable enough to not be cost prohibitive. I think it's pretty much the same as the product they recommended in the restoration video just made by somebody else.
It's basically one use only product so it only makes sense to have a bunch of headlights all ready to be sprayed so you can get as many as you can clear coated and restored with the one can. I would do my HHR's and my 4Runner's headlights with it and maybe a friend or two's as well if they could get theirs sanded and ready to coat at the same time.
Old Jul 10, 2022 | 10:21 AM
  #35
KArthur's Avatar
The coating I sprayed on went foggy and nasty after a couple of weeks.
I seen in post #25 that you used "UV 2X". Can you tell us what this was exactly?
I am going to wet sand and spray mine and did not want to use what you did if it went foggy.
Thanks
Old Jul 10, 2022 | 10:28 AM
  #36
This was the product , I used it in October, so possibly not within the temperature range the instructions suggest
Rocket Dawg
Maintenance and Upkeep
15
Oct 3, 2022 08:42 AM
guppy
Oct 18, 2018 08:17 AM
bartSS
Mar 7, 2011 06:09 PM
Harley99
Jul 22, 2009 10:46 PM
jpmcnam58
Jun 19, 2009 08:06 AM
