Do you change oil according to the oil life monitor?
Having just picked up our HHR last week, it has 160K on it and the oil was changed before it was purchased. For my next oil change, I'd like to switch to synthetic. I'm thinking this would not be an issue at this point but wanted to make sure with you guys since you're all so knowledgeable and stuff :)
If you do, keep a real close eye on the oil level. I changed over to synthetic at high mileage, and it gobbled a quart of it real fast, and I had to add more way before the next oil change. Previously it hardly used a drop between changes. I've returned back to regular oil, and consumption has returned back to normal.
Lucky......
454 engines are known to use oil between changes. In fact it was an in house joke between GM technicians that GM's oil consumption guideline was created by the 454 engine team.
I used about a quart between synthetic oil changes of between 4000-5000 miles in my 454 truck. which was not run hard and only accelerated heavily on freeway entrance ramps.
So, depending on your oil change mileage, your consumption rate is normal.
JWA
16
Jun 21, 2014 12:16 PM
badassbowtie
Maintenance and Upkeep
23
May 12, 2013 02:01 PM
Black Rose
Feb 5, 2007 01:57 PM
