Do you change oil according to the oil life monitor?
Old Nov 4, 2013 | 08:42 PM
  #61
Snoopy's Avatar
Originally Posted by brown1243
has anyone driven a spark or a sonic
Hmmmmmm .....
Thought we were talking (2 years ago) about oil changes???
Old Nov 5, 2013 | 07:22 AM
  #62
1swt4dr's Avatar
Having just picked up our HHR last week, it has 160K on it and the oil was changed before it was purchased. For my next oil change, I'd like to switch to synthetic. I'm thinking this would not be an issue at this point but wanted to make sure with you guys since you're all so knowledgeable and stuff :)
Old Nov 5, 2013 | 12:26 PM
  #63
If you do, keep a real close eye on the oil level. I changed over to synthetic at high mileage, and it gobbled a quart of it real fast, and I had to add more way before the next oil change. Previously it hardly used a drop between changes. I've returned back to regular oil, and consumption has returned back to normal.
Old Nov 6, 2013 | 04:38 AM
  #64
Lucky's Avatar
I have used synthetic for years. I have not seen any oil consumption but I will have to watch closer as miles get higher. I do has a 95 suburban 454 with 208000 miles It uses a quart or two between oil changes I have never thought about changing back to regular oil.
Old Nov 6, 2013 | 11:35 AM
  #65
Snoopy's Avatar
Lucky......
454 engines are known to use oil between changes. In fact it was an in house joke between GM technicians that GM's oil consumption guideline was created by the 454 engine team.
I used about a quart between synthetic oil changes of between 4000-5000 miles in my 454 truck. which was not run hard and only accelerated heavily on freeway entrance ramps.
So, depending on your oil change mileage, your consumption rate is normal.
Old Nov 10, 2013 | 05:09 PM
  #66
jimfet's Avatar
I change my oil once a year, with Mobil 1. I only put around 5500 miles on my car a year.
Old Nov 10, 2013 | 11:32 PM
  #67
X 2
Old Nov 10, 2013 | 11:44 PM
  #68
Gee, I thought you were a "by the book" guy Sleeper. I believe the book says "or 6 months".
Old Nov 10, 2013 | 11:48 PM
  #69
Don- kinda sorta, when convienent.. IIRC book says NOT longer than 1 year.
JWA
16
Jun 21, 2014 12:16 PM
ivyrose
May 25, 2013 04:53 AM
badassbowtie
Maintenance and Upkeep
23
May 12, 2013 02:01 PM
HHR_style
Oct 3, 2009 11:11 PM
Black Rose
Feb 5, 2007 01:57 PM
