Jack Lifting Positions
Old Jun 16, 2011 | 10:32 PM
speedwagen's Avatar
Thanks to all for taking the time to post your advice. So up it goes Saturday for some brake work.
Old Jun 16, 2011 | 11:08 PM
Originally Posted by IgottaWoody
I used the cross bar in the front..but then I have a low pro jack...its how I rotate all tires at the same time..I usually clean the wheels inside out during this. never had any problems on either SS or LS
X 3, floor jack & up she goes..
Old May 29, 2014 | 01:39 PM
Darryl_B's Avatar
Ok this all seem good but what about the cross member just behind the (automatic) transmission i tried it a little and you could lift both wheels at once what i want to know is the cross member strong enough to do that then one could put the jack stands under it and yes i work safely have been for many many years just want to throw in my 2 cents worth on the option of jacking with floor jack on the cross member and i do not trust jack stands by them selves by the way i always use other support like the jack also as a backup .
Old May 29, 2014 | 03:26 PM
That's the cradle. I wouldn't do it. I use the official points and put my stands under the flat spots on the frame horns.
Goose
Dec 3, 2014 10:00 PM
Haunted_Hot_Rod
Jul 26, 2012 09:38 PM
Marcruger
"How To" Tutorial Library
Nov 1, 2009 11:50 AM
Krusty
22
Aug 25, 2008 04:59 PM
HHR-FordRules
Nov 8, 2005 11:50 PM
