Lower control arm problem
Old Aug 2, 2024 | 11:52 AM
Rocket Dawg's Avatar
Left front lower control arm rear bolt that goes thru the frame just spins. The blind nut inside the frame let loose. Im guessing a hole has to be cut into the frame to get at it and a nut welded back in. This happened a couple of years ago and its been tight enough but it really wasn't torqued and now it clunks going around corners and while braking. backing up it makes the noise as well. The bushing is probable gone in the LCA. Anybody ever tackle such a problem?
Old Aug 2, 2024 | 12:51 PM
Yes, several have.
Old Aug 2, 2024 | 12:56 PM
I used a pair of 10 “ vise grips to hold the cage nut , then used my impact gun to back the bolt out! I’ll save you the hours of trying different things to get this done
Old Aug 2, 2024 | 01:03 PM
You had to cut an access hole in the frame, right?
Old Aug 2, 2024 | 01:45 PM
No , I reached in from the driver’s side.
Old Aug 3, 2024 | 06:56 AM
Interesting. I'll get it up on jack stands and take a closer look. That's really nice to know. thank you. I figured I'd have to take it in to a mechanic, but i think I'll tackle this one myself. thanks again. I have the Moog replacements on it from about 4 years ago. One ball joint didnt last 1 year on the drivers side, so I replaced just the ball joint. After struggling with it for quite some time I decided to remove the LCA and thats when the bolt just spun.
Mookie1
27
Mar 11, 2024 08:31 AM
FirstGenHHR06
Maintenance and Upkeep
20
Jul 24, 2023 09:36 PM
courcy
Mar 30, 2023 09:08 AM
Cabernetman
Dec 30, 2012 04:16 PM
bigw10921
Jul 17, 2010 10:35 AM
