oil change info
Old Mar 1, 2010 | 08:23 AM
  #31
spirited driver's Avatar
Nice, that's exactly what I've been looking for! Too bad that site charges a $10 surcharge on all orders under $25, turning a $6 socket in $25 (with shipping) Amazon had it for $12.33 with shipping. Done deal, thanks again!
Originally Posted by 87silver
A standard 32mm socket will not be able to fit onto the oil filter caps on some engines. I bought a standard depth 32mm for my 2.0LNF. You have to put the socket onto the hex first, then put the extension on the socket, but it works just fine.
My son recently changed the oil on his new '09 Cobalt for the 1st time and there was no way to get the 32mm socket onto the 2.2LAP. Because we were already in the middle of the stream, we had no choice but to carefully do it hack style with channel-locks, but decided that this cannot be the norm. We didn't marr the cap, but just the same, we like to do things properly.
Some HHRs may have the same problem.
We have since picked up a Lisle P/N: 14700 Desc: Oil Filter Wrench for GM2.2L. It was under $7. It is lower in profile and fits on easily.
http://www.thetoolwarehouse.net/p-2983-lisle-14700.aspx
Old May 21, 2011 | 08:38 AM
  #32
av61HHR's Avatar
Hi; Thank you for the help. Changing the oil was easy with you post. Have a great day
Alan
Old May 22, 2011 | 12:01 AM
  #33
Don't forget to add a magnetic oil drain plug.
Here's mine:
Old Sep 17, 2011 | 06:54 PM
  #34
RRAMOS's Avatar
Originally Posted by mitzkity
Oh gosh... ... but what you don't see is all the OTHER times I have used the search before I stuck my neck out there. I even warned a noob just now about it because I had ALREADY FOUND THEM and felt silly ENOUGH... ... There's a night's reading there!
Mitzkity,
Where did you get that cool sunvisor?
JWA
16
Jun 21, 2014 12:16 PM
badassbowtie
Maintenance and Upkeep
23
May 12, 2013 02:01 PM
Beachbum1
Apr 6, 2010 09:27 AM
solman98
Jul 24, 2007 06:19 AM
