Oil filter cap removal
Old 10-13-2013, 06:49 PM
LVJJJ's Avatar
Just joined up so this has probably been discussed before, but, I need to ask. I find that getting the oil filter cap off is a gigantic hassell. Have to use big pliers to grip the top "nut" and reef on it. There are so many tubes and cables in the way that I can't turn it more than 1/4th turn each time. Is there a special tool? Also, why not a screw on cartridge filter?, Chevy botched this one.
Love my downsized 1950 Suburban!!!!!!!!
LVJJJ is offline
Old 10-13-2013, 06:52 PM
32 mm shallow 3/8" drive socket and 12 " extension works for me
Oldblue is offline
Old 10-13-2013, 07:11 PM
badassbowtie's Avatar
Do you have a SS????
If you have a SS, It is a little different. you need a flex extension because the upper charge pipe is in the way
badassbowtie is offline
Old 10-13-2013, 07:16 PM
Nope I got me a 2.2 lt
Oldblue is offline
Old 10-13-2013, 07:23 PM
I can see yours!!! I meant the question to LVJJJ
Old 10-13-2013, 08:17 PM
LVJJJ's Avatar
Originally Posted by badassbowtie
i can see yours!!! I meant the question to lvjjj
2.2 lt
LVJJJ is offline
Old 10-13-2013, 08:21 PM
No flex extension needed. Just put the stubby socket by itself on the cap first, then slide a 12" extension straight down past the bracket and into the socket.
At least it works on an SS.
As far as using pliers: PLEASE say you didn't do that.
Attachment 15277
firemangeorge is online now
Old 10-14-2013, 09:56 AM
Go to your local auto parts store and look in the oil change tools section the socket is there.
donbrew is offline
Old 10-14-2013, 04:59 PM
Rod Run's Avatar
Chevy didn't botch it at all. They couldn't have done it anymore right. They have finally designed a very easy to remove filter, that leaves no mess when you remove it.
It's just like any other oil change, except easier. If you don't have the proper tools, it's going to make it a bit harder.
Rod Run is offline
Old 12-14-2013, 03:29 PM
I'm bored today. Just noticed this thread was in the "how to" forum, I moved it.
donbrew is offline
Quick Reply: Oil filter cap removal
