oil leak???
Old 05-14-2017, 01:54 PM
87z16's Avatar
oil leak???
hey everyone HAPPY MOTHERS DAY!!!
I have a question. couple of weeks ago i notice an oil leak under my HHR. i finally got to look and here is what i see.
from the top:
from under the engine at the connection to the tranny:
by the starter:
back of the engine:
what do you people think??
it seems more of a leak then just the cam cover. is there anything else that this engine is prone to leak from??
Last edited by RJ_RS_SS_350; 05-14-2017 at 02:59 PM. Reason: moved pics from end of post, into post
87z16 is offline
Old 05-14-2017, 01:57 PM
87z16's Avatar
oh yeah i should state that it is a 2006 2.4l with about 70k. but you people should be able to tell by looking at the pics right??? lol
87z16 is offline
Old 05-14-2017, 03:40 PM
I'd check the oil pressure sending unit it's just above the starter
https://www.chevyhhr.net/forums/how-...ng-unit-57962/
Oldblue is offline
Old 05-14-2017, 06:22 PM
And the filter cover, and the person that changed the filter last may just be sloppy.
donbrew is offline
Old 05-15-2017, 01:19 PM
87z16's Avatar
THANK YOU BOTH!!
Oldblue - i was thinking that way because on the old sbc was normally the culprit as well. wasnt sure if they had one on this engine nor where to even look. that is my first thing that i will do. seems easiest and cheapest!! THANKS!!
donbrew - i know i can be messy but in this case it is super clean!!! but i will make sure that the cap is snug. well on second thought this is the first thing that i will do. THANKS!! i hope it isnt my fault...
87z16 is offline
Old 05-15-2017, 07:27 PM
J W Davis's Avatar
Mine developed a leak at the filter housing. It was tight, but the gasket had not been replaced as it should every time the filter was changed. Gasket got old and hard and started to leak shortly after last oil change. Bought new filter again and installed new gasket...problem solved. Even the oil change guy at the dealership gets lazy some times or just a new hire learning how to do it.
J W Davis is offline
Old 05-15-2017, 07:33 PM
aradmahogany's Avatar
The oem green gasket actually lasts a long time.get it online or at the dealer. I don't want to start a debate but you really don't need to change it every time you do a change.
aradmahogany is offline
Old 05-15-2017, 07:37 PM
J W Davis's Avatar
You are right, but it seems "they" the dealership had not replaced it in years of service. I only let them do it because it was part of the "deal" when I special ordered the car back in late 2007....lifetime free oil changes.
Old 05-15-2017, 07:39 PM
Lifetime? I bet they never expected these cars to last so long!
Old 05-15-2017, 09:12 PM
I wonder just how many of those new O-rings out of the box you would find in the trash at a dealership.
I had one of those lifetime oil change deals on a Toyota P/U; after the 20th change they started making it impossible to deal with. First they insisted it had to be done at exactly 3,000 mile intervals, even though the Owner Manual said 7,000. Then they started making getting a mandatory appointment impossible, then making me wait for them to finish the drive ins. Not even mentioning all the crap they tried to sell me.
donbrew is offline
Quick Reply: oil leak???
