oil leak???
Old May 16, 2017 | 07:03 AM
There is no such thing as a free lunch or oil changes ! Just an opportunity to sell you something else.
Or my favourite bad mouth the car after awhile and get you to trade it in.
Old May 22, 2017 | 12:09 PM
87z16's Avatar
ok, took off the starter and noticed that the sending unit was dry:
looked in the hole for the starter at the flywheel was all dry:
appears to be my pan:
anything else i should check??
Attached Thumbnails oil leak???-20170519_205145%5B1%5D.jpg   oil leak???-20170519_205209%5B1%5D.jpg   oil leak???-20170519_205232%5B1%5D.jpg
Old May 22, 2017 | 01:19 PM
Looks like it's coming from this huge hole to me. In other words; the starter isn't mounted tight enough?
Old May 22, 2017 | 02:18 PM
Give that area a spray of brake cleaner, and snug the pan bolts , it looks like run off from oil filter changes!
Old May 23, 2017 | 09:03 PM
87z16's Avatar
donbrew --- hmmm oil resides in the flywheel area??? those bolts were incredibly tight. i will retorque them tho.
old blue --- after the retorque or actually first i will just clean off the area. i lean towards the oil pan gasket. i will retorque those as well. the leak seems quite a bit more than over flo. is there a place on these engines for the oil from runoff to pool until it tilts/shifts??
THANK YOU BOTH!!
does anyone know if these pans are hard to do?? ive done chevy 8's buick 6's dodge slant 6 they werent that hard just too many bolts!!!!
Old May 24, 2017 | 07:55 AM
Oil pan is relatively easy, no gasket just RTV silicone. Per
https://www.chevyhhr.net/forums/gene...uestion-49565/
Old May 24, 2017 | 08:07 AM
aradmahogany's Avatar
Don't forget to gently remove the old gasket material from both the block and pan!
Old May 24, 2017 | 09:48 AM
87z16 - no, oil does not reside in the flywheel area.
Old May 24, 2017 | 11:22 AM
However, the rear main crankshaft seal does.
Old May 24, 2017 | 05:52 PM
And oil will take up residence if the rear main starts leaking!!
