Oil usage
Old Jul 28, 2017 | 07:19 PM
According to my compression numbers the rings are ok, but ten years old with a 1/4 million miles on them.
Old Jul 28, 2017 | 08:13 PM
What compression results did you get?
Old Jul 28, 2017 | 08:17 PM
#2- 145
#3- 150
#4- 145
I had a look with a boroscope, the intakes aren't caked like in the turbo engines, but the oil consumption killed my catalytic converter.
The test was last October after I changed the timing and balance shaft chains.
My oil isn't filling up the catch can, I did move the catchcan down and over to the engine lift loop by the upper engine mount.
Old Jul 28, 2017 | 08:37 PM
#1- 145
#2- 145
#3- 150
#4- 145
Those are pretty darn good numbers. I know you had some oil in that tube, but maybe your cat was murdered by oil getting past the guides(or combination)?
OP may have much different compression results.
Old Jul 29, 2017 | 12:29 PM
True, I believe I'm gonna be doing valve guide seals, this winter, that might ease the oil , but it's not getting past the catch can intake hose.
Redshift
Dec 10, 2010 09:48 PM
HotrodHomeRecker
Dec 14, 2009 11:36 PM
esmarkey
Feb 10, 2009 09:34 PM
Hotrodbob
Oct 2, 2007 11:20 PM
EL_REY
2.4L Performance Tech
14
Aug 28, 2006 06:53 AM
