Piston height in bore
Old Aug 12, 2015 | 02:21 PM
cobra94svt's Avatar
I was setting my #1 piston at tdc to prepare for installing my cylinder head. I noticed the #1 piston is lower in the bore as 2,3,4 when they are at tdc. I've been chasing a tick knock noise in my 08 2.2. Thought it wa the timing tensioner, so put all new timing set and tensioner. It jumped time so I pulled the head off and no damage to the Pistons or head and valves but noticed that the cam followers were solid on the exhaust side and after reading a tsb about oil galleries becoming plugged and causing cam follower failure and knocking. So I repkaced them and currently reassembling everything when I noticed this piston height.
Old Aug 12, 2015 | 02:34 PM
Sounds serious. If it is truly lower, then the only thing I could think of would be a possible bent rod.
Old Aug 12, 2015 | 02:52 PM
cobra94svt's Avatar
Well that sucks. Guess I'm going to drop the oil pan real quick. Damn!!!
Old Aug 12, 2015 | 04:47 PM
cobra94svt's Avatar
Well got the oil pan off and not good, #1 rod is loose, haven't gotten it out, but time for football practice for my 9yo. Will get the rod, piston out this evening. I'm thinking spun rod bearing.
Old Aug 12, 2015 | 08:05 PM
cobra94svt's Avatar
Well it spun a rod bearing, the crank still looks good, no scarring or grooves. Anyone want to buy a HHR??? 90,xxx miles lol.
DarkKnight
Nov 4, 2014 12:29 PM
eaglefreak138
Tires & Wheels
Oct 16, 2011 12:11 AM
pstar
12
Sep 23, 2011 06:35 PM
ChevyMgr
2.0L Performance Tech
54
Jun 8, 2010 06:51 AM
prod
Tires & Wheels
Jun 8, 2009 10:19 AM
