Plugs after 115K
Old Jan 3, 2015 | 12:00 PM
mjhhr's Avatar
Plugs after 115K
Changed plugs this morning after gradual decline in performance. Mileage seems to still be good. But don't wait this long or they may become a permanent part of the head as the threads were quite rusty - given the amount of alcohol and water in the gas these days.
Old Jan 3, 2015 | 12:08 PM
Snoopy's Avatar
" given the amount of alcohol and water....."
Unless you have a major compression problem with your engine(excessive by-pass thru the thread area)you shouldn't have any fuel, water or alcohol on the threads of the spark plugs. The rust and corrosion is a result of dissimilar metals and external moisture.
Old Jan 3, 2015 | 11:51 PM
Time machine!
Old Jan 4, 2015 | 08:57 AM
Originally Posted by donbrew
Time machine!
I split this off from the original 5+year old thread, just to let y'all know, that way donbrew's comment won't seem utterly out of context.
aboard mjhhr!
As Snoopy stated, you really shouldn't see rust on the plugs. Carbon accumulations, yes, but not rust unless there's a situation where coolant is finding its way into the cylinders...or if the plugs that came out weren't the proper AC Delco 41-103 Iridium models.
Old Jan 4, 2015 | 09:40 AM
And a coat of never seize on the threads to prevent galling
asanti
Maintenance and Upkeep
34
Apr 19, 2024 11:55 AM
goseecal
Drivetrain (Excluding Engine)
Oct 29, 2014 12:07 PM
CamSweet
May 13, 2014 10:27 AM
gangster moblie
42
Sep 5, 2011 05:54 PM
barfan1
Apr 12, 2011 11:43 AM
