Radiator Drain
Old Oct 12, 2011 | 02:15 AM
Well son-of-a-gun!!! http://www.sjdiscounttools.com/the485.html Ya learn something every day.
One of them looks like it is designed for the old brass type or http://www.class1.com/Main/Products,796,796.aspx
This is what the "valve stopper-upper" on the HHR looks like -
http://www.rockauto.com/catalog/x,ca...,parttype,2176
(sorry for small picture) they are pretty light duty (just plastic) and are supposed to be just hand-tightened/removed - so if you have to use a socket on it, I think one is going to have bigger problems on the horizon.
Last edited by whopper; Oct 12, 2011 at 11:39 AM. Reason: forgot link to picture of offending part
Old Oct 12, 2011 | 08:04 AM
JoeR's Avatar
petC O C K
There, I said it!
Old Oct 12, 2011 | 10:18 AM
Originally Posted by JoeR
petC O C K
There, I said it!
You always have the answer Joe !!!
Old Oct 12, 2011 | 11:37 AM
Talking
Sir, you have a P O T T Y mouth!!!
Old Oct 12, 2011 | 05:35 PM
And you thought that there are no Special tools!
The real problem I had was that plastic to plastic threads with ant-freeze added just have a little too much friction for the 2 fingers that there is room for up there, even after it is loosened up.
BTW, you do not have to remove the whole thingie, it is a drain thingie, so you only need to open it till coolant flows. However, it flows pretty slowly. so I ended up removing it. The head gasket repair I was doing required draining the system several times, my fingers still hurt "I got blisters on me fingers" (that's a Beatles reference).
Old Oct 13, 2011 | 03:11 AM
Sorry I mentioned it!!
Yeah it's almost like a friction fit - I think I loosed mine from the top. And yeah, it does flow slowly.
Old Oct 21, 2011 | 01:19 PM
BlackScreaminMachine's Avatar
Petcawk
Petcox
Petkok
Petcoc
Petcok
Or Petrooster
Figure I would see what would pass.
The only tool I ever used was for leverage IF over tight, some pump pliers. Depends on the car. I will be doing this job bright and early tommorrow.
Old Oct 21, 2011 | 03:17 PM
Originally Posted by BlackScreaminMachine
Petcawk
Petcox
Petkok
Petcoc
Petcok
Or Petrooster
Good luck, plastic on plastic does not need to be over tight to be difficult! It's not just the initial twist that's the problem. The inaccessability engineers were hard at work on this one, it only has 1 dog and there is not enough room to get a 180 degree turn with the pliers, so you will end up messing the plastic up.
Maybe if you liberally apply duct tape to the plier jaws you can avoid damage.
Old Oct 21, 2011 | 04:19 PM
Yea, I can throw some on. After working on F bodies, you tend to look at cramp spaces differently
slantram
Maintenance and Upkeep
Jul 10, 2014 09:25 AM
Cardwiz428
Dec 23, 2013 07:59 PM
Elizabeth
May 30, 2012 08:46 AM
RICK167448
Apr 13, 2011 12:19 AM
slantram
May 8, 2010 06:08 PM
