Remove engine air filter cover
Hi, again guys
i was wondering if you have to remove the big plastic cover to get to the oil and air filter? Sounds stupid, but on some cars when you unplug the air mass sensor you get an engine yellow code light after service. Or does that only happen if you start it unplugged. ?
https://www.chevyhhr.net/forums/how-...-filter-57663/
remember to plug it back in.
https://www.chevyhhr.net/forums/main...own-oil-10546/
The oil filter isn't under the air box.
x2 what Don says.
About the only reason to need to remove the plastic cover is to change the sparkplugs, or change the air filter.
The engine check light will only come on if the engine is started with the MAF disconnected.
