Service Traction control and ESC light on the dash
Old Apr 24, 2022 | 01:04 PM
Rocket Dawg's Avatar
I just started it and drove it out to my mancave to work on it. It runs on all 4 cylinders, the "service traction control" light is gone/off, and code 0353 isnt in the OBDII reader anymore. Just the 0303 and I erased that and it didnt come back. No check engine light either. It's going to have all the connections cleaned and that spring checked out. It was 100% humidity the other evening. It's close to 90% humidity right now and light rain showers. More than likely a connection issue. Does anyone replace ignition coils as part of regular maintenance? I mean is 209k on these coils operating on borrowed time?
Old Apr 24, 2022 | 01:46 PM
I’ve put way more miles on Oldblue and still OEM coils.
Old Apr 25, 2022 | 08:49 AM
Thanks, I'll clean the connections this afternoon.
Old Apr 25, 2022 | 11:47 AM
fastsuv's Avatar
Make sure the coil connectors are fully seated. You should hear an audible "click" as they lock in.
They can look fully seated but not be. They are very sensitive to being fully seated. Once I had a problem similar to yours (didn't have traction control or ESC so no Service traction or ESC message) where one cylinder appeared to die every so often. I had pulled the coil connectors and I had not fully seated the connector on one cylinder until the click. Pushed it in harder until click, no problems after that.
Steve
Old Apr 25, 2022 | 11:57 AM
Thanks for that info, heading out to work on it now.
Old Apr 25, 2022 | 04:15 PM
All the symptoms returned today. New coil and spark plug. Less than 5 minutes of work and we're back on the road again.
Old Apr 26, 2022 | 07:59 AM
With or without those symptoms?
Old Apr 26, 2022 | 02:56 PM
Okay, all the symptoms returned from post number 1 and the new coil and spark plug fixed it. Put about 20 miles on it today and it runs great.
Old Apr 26, 2022 | 03:07 PM
That’s what I was hoping you meant! Awesome it’s fixed!! Enjoy the drive!
scubanut
27
Jul 9, 2024 09:51 PM
janoka
Oct 30, 2021 09:43 PM
captneuman
Jun 6, 2021 11:42 AM
Eric Overmiller
Mar 22, 2018 10:07 PM
Alexwsilver2010
Aug 9, 2014 10:41 AM
