Sway Bar Bushings..Should I attempt myself?
we do have a firestone and again..lol.. i thought they only did tires....I'll have to give them a call....thanks again....I use to be able to do this work so I never really had a need for a shop.
We have a couple small 2 /3 man shops around but they are over run with jobs. The small shops are back logged.....
Thanks again to all helping me out here, very much appreciated !
Mike
Because they are good and cheaper?
Sway bar is not a safety issue, unless you are a "road racer" it can wait.
Even before I got sick the bushings were a major pain in the butt for as simple a job as it is.
Drives me crazy when I hit a slight bump.
Your better off getting the poly bushings as long they are for your size sway bay and will fit the OEM "clam shell" for them. If not get the bracket that goes with the aftermarket poly bushing.
Firestone is ordering them from moog? not sure what they ordered other than I told them poly bushings....
I sure take it as easy as I can when driving , trying not to drive much till it get's fixed....
