Sway Bar Bushings..Should I attempt myself?
Old Apr 2, 2018 | 05:28 AM
kamikaze3557's Avatar
we do have a firestone and again..lol.. i thought they only did tires....I'll have to give them a call....thanks again....I use to be able to do this work so I never really had a need for a shop.
Old Apr 2, 2018 | 08:25 AM
Cat Man HHR's Avatar
There aren't no local shops in your area ?
I also feel your pain about doing self repairs. I'm still healthy but wish I had a building and lift. 67 is the number people tell me I am.
Old Apr 2, 2018 | 08:40 AM
I prefer small 1-2 man shops. The usually don't do flat rate books, they use real time.
Old Apr 2, 2018 | 09:42 AM
Docs orders not to exert myself (upper body, arms) do to CHF, but he want's me to walk my Azz off.
We have a couple small 2 /3 man shops around but they are over run with jobs. The small shops are back logged.....
Old Apr 2, 2018 | 09:51 AM
I did finally get into the local Firestone, and they are trying to get me some poly bushings, I just returned from there and they ordered some from Moog that they hope will fit, won't know until tomorrow when they get them in and check the fitting.....if not I will have to go to OEM, still it will cost me $170 just for the bushing replacement...but that is what they can charge sense all shops are overloaded around this small town. They check out the whole front end and said everything else looks really good...I will have them check the back end for me sense I "think" I hear a noise / clunk from the back, tho it's hard to tell with the front clucking, may be an echo...lol
Thanks again to all helping me out here, very much appreciated !
Mike
Old Apr 2, 2018 | 09:57 AM
Because they are good and cheaper?
Sway bar is not a safety issue, unless you are a "road racer" it can wait.
Even before I got sick the bushings were a major pain in the butt for as simple a job as it is.
Old Apr 2, 2018 | 10:14 AM
The passenger side bushing is almost non existent, it just bangs against the retainer? ....and the other side is getting there....
Drives me crazy when I hit a slight bump.
Old Apr 2, 2018 | 10:27 AM
Don't go racing on curvy roads until it gets fixed.
Old Apr 2, 2018 | 10:40 AM
Your better off getting the poly bushings as long they are for your size sway bay and will fit the OEM "clam shell" for them. If not get the bracket that goes with the aftermarket poly bushing.
Old Apr 2, 2018 | 01:17 PM
Firestone is ordering them from moog? not sure what they ordered other than I told them poly bushings....
I sure take it as easy as I can when driving , trying not to drive much till it get's fixed....
