Sway Bar Bushings..Should I attempt myself?
Old Apr 14, 2018 | 04:20 PM
  #31
My wrench hands are 32, good old Dan , he loves to learn how to work on old cars, Oldblue, he calls an old car! Mine he was just 21, when my HHR was assembled.
Old Apr 24, 2018 | 09:54 AM
  #32
kamikaze3557's Avatar
Final Update:
Got the sway bar bushing installed by a local shop (Covington tire & lube) I had already purchased the Moog End Links and asked if they would install them too, wasn't sure if they would install parts you bring in, they said they do it all the time...good thing I had them, they had to use a cutting torch to remove the old End Links...it took them over 4 hours to do the job and charged me only $150.00 even. To me that was a deal considering they took as long as they did.
Finally have a nice smooth reasonably quiet ride....
Thanks again for all the advice and heads up from those who responded to my post......Ride on !
Mike Cossey
Old Apr 24, 2018 | 01:41 PM
  #33
Cat Man HHR's Avatar
Out of curiosity, what is that shops hourly rate ?
Old Apr 24, 2018 | 01:47 PM
  #34
Cat Man
On their wall it says 65 per hour but he quoted me 55 (over the phone).....I've done business with them before but only tires and oil / filter change...
Old Apr 24, 2018 | 02:46 PM
  #35
$150 for 4 hrs is $37.50 an hour. You made out.
Old Apr 24, 2018 | 03:00 PM
  #36
That's how I felt, they have my business..but I expect normal rates next time.I need them...
Old Apr 24, 2018 | 04:44 PM
  #37
Except when you lookup the flat rate: bushings .7 hour, links .6 hour. 1.3 hours = $115/hour.
Usually the flat rate time is greatly inflated. Very few shops charge actual time, because the technicians might be working on 6 jobs at the same time and it is difficult to log the time.
EricHHR
69
Aug 30, 2014 09:42 PM
igotgas
10
May 5, 2011 12:53 PM
moonsign
15
Apr 8, 2011 11:06 PM
moonsign
0
Dec 9, 2010 10:23 PM
Sneezy
55
Sep 17, 2010 11:25 AM
