Transmission Service
So, I'm hearing several ways to do this. There is a black plastic cap on top of the tranny under the brake master cylinder. Can I refill the tranny thru this port or not?
I have the FSM, I’ve seen the drawing supplied in post #3 and still can’t find this transmission vent/fill port. I’ve read the descriptions of its location, but…
I’m sure it is simple – I just cannot visualize/find it under the hood. Can someone provide a picture?
It's down behind the thermostat housing hidden under the wires, it is about 1.5-2 inches high. Getting a good pic would be a challenge, once you push the wires around and put your hand down there you'll find it. Hand tighten and loosen only!
~3 inches forward of the thermostat housing and ~2 inches toward the drivers side. Damm those wires.
Lake Runner
Dec 10, 2012 09:33 AM
