Windshield Washer Fluid Pump
Old Apr 14, 2018 | 03:51 PM
UWZerokoolX's Avatar
Okay, I cannot justify buying an entirely new forty dollar Windshield Washer Pump just for the rubber gromet that seals it to the windshield washer resvoir. Does anyone have a part number for the rubber gromet?
Old Apr 14, 2018 | 04:03 PM
Read post number 8, while this may or may not correct your issue , hey it’s inexpensive and may save you a few bucks.
https://www.chevyhhr.net/forums/main...eak-fix-54278/
Usually it is the internal seal that fails, especially in freezing weather, that looks like the grommet is leaking.
You would probably have to go to a store that has jobber boxes to match one up. Bad news is not all new pumps come with a new gasket.
They can be had for closer to $30. https://www.ebay.com/itm/ACDelco-193...tWqOzJ&vxp=mtr
Old Apr 14, 2018 | 04:08 PM
Yeah I just got done reading that blue. I was hoping that someone would come up with a part number by now.
And don't you worry don, I am not going to wig out on you.
I might as well do the simple cheap fix... I already have my air intake hose duct taped because I cant find the part number for that either. -_- *Deskface* argh!
Old Apr 14, 2018 | 04:16 PM
You might try
a. looking in the part number thread
b. looking at an online GM parts store like this: https://www.gmpartsgiant.com/parts-l...ke-system.html
Old Apr 14, 2018 | 04:17 PM
Air intake duct hose, commonly called the Woolley Worm.
One solution
https://www.chevyhhr.net/forums/prob...problem-53013/
Wolley worm part number in post #9 here
https://www.chevyhhr.net/forums/main...cleaner-58572/
Old Apr 14, 2018 | 04:21 PM
https://www.chevyhhr.net/forums/comm...33/#post791993
Old Apr 20, 2018 | 02:01 PM
4silverado's Avatar
I don't know if this helps, but I picked up a 2011 back in January. It would dump washer fluid on the ground faster than you could dump it in. I removed the reservoir thinking that it might be cracked; the pump grommet was bad. I wiped everything down and applied a liberal amount of blue silicone and put everything back together. I waited a full week before adding fluid. So far, it's holding fluid with no issues.
knelson1969
Maintenance and Upkeep
10
Mar 31, 2017 08:10 AM
gio89kid
Dec 12, 2015 07:54 PM
phenderson51
Jan 21, 2014 02:46 PM
Jeff®
Sep 1, 2013 10:32 PM
