Paint the Rear of the Muffler .. Anybody ??
A minor problem I have with cleaning with any solvent is that they leave a film behind.
Try it on your HHR front side window by wiping the solvent on the clean clear glass with a clean rag and let it dry.
Do it on a sunny day and with the window facing the sun. Then look at it to see if it is perfectly clear or some residues left behind.
Thats why I finish the job with an industrial water based liquid cleaner and rinse with clear water. I dob lightly with a clean paper towel. If lint is still a problem I use a New small 2" bristle brush to de-lint, then finish dry with a hair dryer.
Surface is then clean and the paint will stick better.
Extra effort ?? ... Yes ... but so is respraying every 6 months.
re
greybeard is correct - really no matter what you use they need to be touched up every few months to be kept fresh looking - they take a lot of abuse under there - also dupont #3812 reducer as a final wipe will remove any film left over by wax and grease remover or sanding sludge if you used a scothch brite
SVT2399
Jun 15, 2010 09:29 PM
bigbear2k
Apr 9, 2008 06:23 AM
BelizeBrian
Jan 30, 2007 02:17 PM
