Mods - Engine/Exhaust EngineCompartment/Exhaust Discussions. (Non-Performace)
Paint the Rear of the Muffler .. Anybody ??
Old Jun 13, 2011 | 08:31 PM
Silverfox's Avatar
A minor problem I have with cleaning with any solvent is that they leave a film behind.
Try it on your HHR front side window by wiping the solvent on the clean clear glass with a clean rag and let it dry.
Do it on a sunny day and with the window facing the sun. Then look at it to see if it is perfectly clear or some residues left behind.
Thats why I finish the job with an industrial water based liquid cleaner and rinse with clear water. I dob lightly with a clean paper towel. If lint is still a problem I use a New small 2" bristle brush to de-lint, then finish dry with a hair dryer.
Surface is then clean and the paint will stick better.
Extra effort ?? ... Yes ... but so is respraying every 6 months.
Old Jun 13, 2011 | 09:09 PM
BBQ paint really only lasts 6 months anyways, regardless of prep. Not that prep isn't important, it's 95% of the job....... Just in this case it may not change the facts.
Old Jun 13, 2011 | 10:23 PM
bassbase's Avatar
Yeah, I used VHT satin black Hi-temp header paint
Old Jun 13, 2011 | 10:43 PM
Silverfox's Avatar
Satin Black sounds like a better choice then flat as it usually inherently has more durability.
How long does it last between coatings ??
What does VHT stand for and did you buy it at a specialty automotive store ??
Old Jun 13, 2011 | 11:10 PM
VHT* = Very High Temperature
Most any Auto Parts store carry this brand..
edit: I use BBQ paint also......
Old Jun 14, 2011 | 06:40 AM
08bowtie's Avatar
re
greybeard is correct - really no matter what you use they need to be touched up every few months to be kept fresh looking - they take a lot of abuse under there - also dupont #3812 reducer as a final wipe will remove any film left over by wax and grease remover or sanding sludge if you used a scothch brite
jimmycrook
Mar 13, 2014 08:02 AM
SVT2399
Jun 15, 2010 09:29 PM
bigbear2k
Apr 9, 2008 06:23 AM
Sunrise HHR
Mar 21, 2008 05:41 PM
BelizeBrian
Jan 30, 2007 02:17 PM
