3rd Brake Light Decal
Ok, this may be a question for ChevyMgr, but do you know if you can buy one of the plastic covers that goes over the brake light that has the 4 clips? Of course I managed to break a second clip off putting it on, and now it rattles...
usefull tip?
i am not sure if this is totally true , but i do know that a lot of things get more brittle when cold , so , it may be better to try to remove panels when they are warm , or hot. maybe let them sit in the sun for a while on warm/hot day , or even on a cold day if you must.
Assuming the clip and broken plastic is still in the slot, just put a glob of RTV between that and the cover, the other clips will hold it in alignment while the RTV sets, and no more rattle. (Yes, I broke mine too). Easy enough to redo whenever you pull the cover off.
NxlKing2304
"How To" Tutorial Library
Apr 10, 2015 12:23 PM
