Custom Designs for my HHR
I like the first one. Good luck.
Quick question on the Depo's. It appears that the orange lens was removed for the turn signal. Is this the case? I would like to have a chrome bulb installed to provide the clear look and get rid of the orange.
Here is the easy button way to get that https://www.chevyhhr.net/forums/deleted-threads-41/don-juans-06-ss-kitd-hhr-37267/
You know, the answer might be to take apart the lense itself. Tape it off. Paint it black. Then add the second light per lense. After all that. Cut out a smaller lense, just for the headlight. Then reseal with epoxy and smooth the edges with a Plastic Welder.
Thanks everyone for your help on this.
I will draw something up using the factory headlamps.
Good to see more people like myself with the same mental issue I have.
Can't leave things alone without modifications!!!
Fender on. I still need an outside support bracket. The junk yard I bought this fender from did not include the hardware needed to install the fender correctly.
Here is a picture of the new fender in place.
Hmmmm, one orange fender, you may have started a new trend here. Just sit back and watch how many other HHR's suddenly have one orange fender, because it is now officially "Cool".
P.S. Just kidding ya know.
