HHR Reverse lights - Urgent Question
to the forum benjie!The dimension of the HHR tail lamps in both the upper and lower positions is 5.0305" OD or 127.78mm.
But the lights themselves are different, you can mount the brake lights in the lower holes with some sheet metal modifications.
