Fog lights question
Old Oct 28, 2011 | 04:49 PM
warhawk77's Avatar
Fog lights question
How much trouble is it to install fog lights if they don't come factory?
I like the looks of them but most of the ones I see don't have them so thinking that will be my first mod.
Old Oct 28, 2011 | 04:57 PM
LawDog88's Avatar
I don't think its too hard. ebay some HHR foglights, that come WITH a switch, and then hook them up, wire them, etc.
Old Oct 28, 2011 | 05:10 PM
warhawk77's Avatar
Looking at some videos looks like it is a bit harder then just plug and play. I will have to make sure I get the kit adjust screw.
Old Oct 28, 2011 | 06:08 PM
jmdomini's Avatar
I just did this a few weeks ago. Went with Depo lights that are a direct fit to the OEM holes. If you've done automotive electrical work before it's not very difficult.
Check out this links below. The first one will give you a rough idea of the overall installation. Don't wire the switch the way he did though, use a relay. The second link talks about relays and has two diagrams showing how they are wired.
Good luck if you decide to go for it!
https://www.chevyhhr.net/forums/how-tutorial-library-21/aftermarket-fog-lights-5524/
http://www.offroaders.com/info/tech-...ive-wiring.htm
Old Oct 31, 2011 | 08:42 PM
ebritt's Avatar
I did it on my HHR. Got fogs from local salvage yard, hooked them up to Daytime Running lights with a relay...no switch needed, they are on whenever the low beams are.
sport
Mods - Exterior
Jan 11, 2013 01:24 PM
benjie
Mods - Exterior
Jun 12, 2012 02:41 PM
Violet_HHR
Dec 12, 2007 09:55 AM
helhedded
Feb 22, 2007 09:43 AM
