A/C outlet in center dash
Nope just pop off the water fall and unscrew the three Philips screws from the back , careful to disconnect the wires to the dimmer switch and the blower switch and power plug there should be enough wire to get the vents out
A quick search looking for 'remove vent" found this which should be helpful: https://www.chevyhhr.net/forums/prob...breaking-6894/
This tsb may help. Post 125. https://www.chevyhhr.net/forums/prob...-23231/page13/
