LED interior lights
LED interior lights
I was thinking of upgrading to LED lights.
Saw some light packages on Ebay
Pros or cons on it?
Or should I buy direct from Super Bright?
Also do I need the CAN style bulb or just use an LED replacement bulb?
Thanks
Pros or cons on it?
Thanks
That is not a proper link to anything.
Is this what you were looking at?
6pcs White LED Lights for Map Dome 1 62" 41mm LICENCE Plate Interior Package | eBay
If so I got a similar set at AutoZone a few years back and like them just fine. Of course it was more expensive back then.
I went into AutoZone that day I was just sorta curious about LED lights. I knew some folks had had to add a resistor to them and they were really mostly a PITA to fool with.
The kit I got was the one recommended for the HHR. I did not have to add anything but the bulb so I just put them in the car and have been using them since.
I did not replace all the dash light tho, those are still whatever came stock. Taking the rear view mirror apart to replace those bulbs was a bit of a learning experience.
Inframan
16
Nov 5, 2013 01:28 PM
Gsus
Jun 26, 2009 12:56 PM
