Replacing interior lights with LED's
I would like to replace my map and dome lights with LED's, but I don't know of a good place to get them. I also would like to know if I need anything special to do this, ie: resistors and such. Thanks in advance for the help, Mike.
Part numbers (from Sylvania)
Dome Light.... #562
Map Light.....#2825
These guys have LED replacements..... http://www.superbrightleds.com/bulb_cross.php
Dome Light.... #562
Map Light.....#2825
Dome Light.... #562
Map Light.....#2825
Dome Light.... #562
Map Light.....#2825
I know you said you found what you are looking for, but for anyone who finds this thread later on searching or who may want some later, I do believe that you can find what you need at Radio Shack as well.
Results, please?
Please report how your interior LEDs compare with the standard incandescents once you get them installed. I love the LED tail light kit but only on my 2nd try getting red ones from a better source did my high-mount brake light individual LEDs give an acceptable result. I have not attempted to use LEDs anywhere else so I am very curious about how yours work out.
Did mine a few weeks ago. I used 16 LED 562 bulbs in the back seat and cargo. Then I did the 194 - 16 LED panels for the front map lights. 194 bulbs work up front also if anyone is wondering what a 2825 is.
Its BRIGHT inside. Looks crisp & clear.
