Mods - Interior Discussion related to the looks of the interior of the HHR.
Seat height
Old Nov 13, 2011 | 09:15 PM
RetiredLE's Avatar
Seat height
Greetings,
We are the new owners of a 2007 HHR LT with cloth interior and power driver/manual passenger seat. Is there a kit out there to lower the front passenger seat?
I don't have a problem when sitting in the drivers seat - but my head touches the headliner when I sit in the passenger side. From what I have been able to see, the only adjustment on the passenger seat is back and forth and recline. Even with the seat all the way back and at a normal recline angle, my head still touches.
I am hoping there is some way to resolve this without having to fabricate custom brackets.
Thanks for reading.
Mike
Old Nov 13, 2011 | 10:38 PM
LawDog88's Avatar
Sad to say, I am the same way, and I have been contemplating this same idea.. I'm told custom brackets is probably how it will have to be.
Old Nov 13, 2011 | 10:47 PM
No kits TIKO.. cut & re-weld the brackets..
Old Nov 13, 2011 | 10:48 PM
Take a look in my gallery photos of my bracket to lower the drivers seat. I made this myself. It might give you some ideas.
Old Nov 13, 2011 | 10:49 PM
No kit offered from GM, I'm guessing you may have a sunroof on your LT, they do rob quite a bit of headroom. While the driver's seat offers either 4-way manual adjustment, or power adjustment depending on the trim level, seat height on the passenger side is fixed.
This would be a job for a custom shop, either one specializing in mobility retrofit applications, or a fully equipped upholstery shop with fabrication capabilities.
Due to the passenger airbag sensor, seat belt pre-tensioners, and the design of the seat tracks....its not a DIY job I'm afraid.
Old Nov 14, 2011 | 12:12 AM
For the record:
"Or you could weigh the seat area down till it sags.. Then you'd be lower.."
Was obviously just joking..
Old Nov 14, 2011 | 12:39 AM
RetiredLE's Avatar
Originally Posted by sleeper
For the record:
Ok, guess I will take off those two demerits I assigned to your account.....
Old Nov 14, 2011 | 02:04 AM
only 2 ?? Thank U..
Old Nov 14, 2011 | 06:55 AM
foolmoon_design's Avatar
Moonsign and a few others have done a mod where they have reversed the brackets, and have fabbed new crossmembers. you gain another 2" with this mod.
Send Moonsign a PM he has many pics of the process.
mchuntley
Mar 7, 2013 10:43 AM
job247
Mar 18, 2012 11:51 PM
B@work
Apr 18, 2011 12:30 PM
Father Azmodius
16
Aug 24, 2009 12:33 PM
andoll83
Jan 8, 2009 07:39 PM
