North Central ND, SD, MN, WI
Transmission on a 2006 2.2 ecotec
Old Aug 20, 2022 | 06:53 AM
  #61
There are 6 bolts to hold the flywheel/flexplate in place and 3 bolts to hold the torque converter to the flywheel/flexplate.
I clean up the area with 1 part Dawn , 3 parts water and a stiff brush . Be careful cleaning near the transmission front seal and the engine rear main crank shaft seal.
The rear main seal area
Old Aug 20, 2022 | 01:47 PM
  #62
FirstGenHHR06's Avatar
Would that flexplate work?
Old Aug 20, 2022 | 02:17 PM
  #63
According to part numbers from Rock auto, it's the same if the Terrain has a 4 cylinder engine, the 6 cylinder is different.
But it's the seller that's going to guarantee fitment, so your question should go to them.
Old Aug 20, 2022 | 02:44 PM
  #64
Yes provlded it’s from a 2.4 l as it appears it is , note three kidney shaped holes, the v6 plate has 4
This is the V6 flexplate, note the 4 holes
This is your 2006 flexplate , 3 holes
This is the same 3 holes and same part number
06 HHR LOVER
Nov 13, 2017 12:49 AM
charged3800z24
2.2L Performance Tech
22
Mar 23, 2016 09:30 AM
4404spd
Dec 2, 2015 11:48 AM
danthemancamaro
Jun 4, 2015 12:18 PM
