06 hhr no rear running lights
Old Nov 23, 2010 | 11:55 PM
Welcome & Good luck back at the Dealer..
Old Nov 24, 2010 | 12:15 AM
IgottaWoody's Avatar
"and i do have power to the sockets in the rear" .............
you have a bad ground at the socket.....
Old Nov 27, 2010 | 07:18 PM
macarchie's Avatar
I'm curious. What did the dealer say?
Upon reading the thread, the first thing I thought was that the light sensor wasn't turning on the headlights and the DRLs were on all the time. That would give you brake lights and backup lights - but no tail lights or side markers. Just a thought. The cruise issue sounds like the LED / circuit load problem.
Old Dec 1, 2010 | 09:51 PM
Tommyy626's Avatar
woo hoo
ok so it turns out someone forgot to tighten the bolts on the fuse block and some wires got loose, the purge solenoid under the hood needed the wiring harness fixed, that is also a service bulletin. so everything is in working order as far as i know we will see in the next few weeks
Old Dec 1, 2010 | 09:55 PM
Glad you got it sorted out
toekra
May 11, 2012 02:25 PM
Sasksurfer
Apr 24, 2010 11:12 AM
BlackHHR
May 5, 2006 12:02 PM
Gqsplack
15
Feb 28, 2006 09:17 AM
