07 HHR 2.2 swap exhaust question
Old Jan 13, 2018 | 03:57 PM
celblazer's Avatar
On your phone, Just click on the picture icon when replying then from device and then files.
Old Jan 13, 2018 | 04:05 PM
203chevyguy's Avatar
Looks like the pic of the 2.2 engine maybe the shop made an error in the 2.0 on the paperwork. But I know it's not the original numbers matching engine.
Old Jan 13, 2018 | 04:07 PM
But the number written on it from the junkyard says 2.0 as well. Which led me to think that it is a 2.0 between the garage paperwork and the junkyard marker paint on the motor
Old Jan 13, 2018 | 04:28 PM
If we’re lucky there will be a label on the passenger side , I’m pretty sure you have a 2.2. To confirm , are there VVT solenoids on the left of #1 spark plug?
Old Jan 13, 2018 | 05:16 PM
Yes there are.
Old Jan 13, 2018 | 09:33 PM
2.0 L Ecotec engines were only made in turbocharged or supercharged versions.
What you have there is a 2.2 or 2.4.
Old Jan 13, 2018 | 09:52 PM
If the VVT valves are connected to the wiring harness, then your HHR was probably not a LS with a 2.2. It probably is a 2LT that came with a 2.4. The 2.2 did not have VVT until 2009. What is the VIN on the dash?
Who's to say that it's not a 2.0? I can't say if the 2.0, 2.4, and 2.2(w/VVT) are any different electronically. Perhaps the 2.0 LSJ from a supercharged Cobalt, with the SC removed, is a direct bolt in.
But let's just wait and see what the numbers on the engine reveal.
Old Jan 14, 2018 | 10:27 AM
You could decode your VIN with this: https://service.gm.com/dealerworld/vincards/. The HHR is listed as a "Light Truck".
That will tell you what engine came in the car.
You could also check the VIN in the ECM to see if the ECM came with your car. If it started out with a 2.2 and now has either a 2.2 or a 2.0 the ECM would have been changed.
In 2007 the 2.4 had VVT the 2.2 did not, they take different ECM programming and wiring harnesses.
Old Jan 15, 2018 | 03:40 PM
Ok, so the original motor was a 2.4. They took the motor ecm and a few other components out of a 2.2 donor car when the 2.4 was blown. So it is a 2.2. Thank you for your help guys. My question is were the bodies and mounting locations for the exhaust on the frame and body the same on the 2.2 and the 2.4 model?
Old Jan 15, 2018 | 03:42 PM
I apologize that I posted in the wrong location due to being misinformed. Future post I now know what motor I have to post the the correct thread.
