07 LT Key Fob problems
I've tried maybe 3 different new key fobs and none of them ever worked. I was told by the dealer that it was the receiver inside the car but I haven't been able to find anything about it. Anyone have an idea?
Did you check battery cage solder points on the old fog? Did the dealer install the new one?
You can't just order a fob and use it; it must be programmed to the car. That takes plugging a computer into the car.
