08 HHR SS scanner connection issues
Old Aug 27, 2022 | 02:12 PM
DC08HHRSS's Avatar
Hmmm so no ideas huh? I don’t think there are any in there my scanner didn’t see any. They are a very well known locksmith too I’d hope they would know!
Old Aug 27, 2022 | 02:17 PM
Originally Posted by donbrew
Are you a digital computer guru? If not all you need to know is that pin #16 is 12V. The usual reaso that locksmiths can't connect is that they need to erase all of the previously programmed fobs first.
Fuse #29 under hood fuse box powers the DLC and the front aux. power connector.
#29 on the BCM is the power windows.
It is the RCDLR that needs programming for the fob and TPMS.
'08 models need a RCDLR firmware update for the TPM to work after a power outage. That should not affect the remote door locks, unless somebody tried to repair something.
Here it is if you think it will help:
as Donbrew states you need to have the RCDLR reprogram preformed. Usually a dealership has to do this .
Old Aug 27, 2022 | 02:28 PM
DC08HHRSS's Avatar
oh boy. Can’t imagine what they’d charge for that. Looks like I’ll be using the key to lock and unlock it lol
Old Aug 27, 2022 | 03:23 PM
Call a couple in your area, get a quote.
Old Aug 27, 2022 | 03:35 PM
DC08HHRSS's Avatar
yeah I’m gonna Monday. I messaged this local who is a killer mechanic I know he is a wicked GM nut hopefully he says he can do it
Old Aug 27, 2022 | 04:34 PM
They are trying to be precise. Your bench DC power supply has ground and positive; don't call it a power supply then?
"Ground" for digital circuits is 0 volts not ground to battery.
Digital low ref can be 0-3 volts, but dead constant, usually 0 because it is easier. Which is why many think 0 is the same as ground.
iluvmud
Jun 28, 2022 01:42 PM
derekjames
Mar 31, 2017 03:25 PM
Php
Mar 13, 2017 07:51 AM
wentzSS
Jun 14, 2015 07:43 PM
jmc2009
Jun 11, 2015 12:30 PM
