09 HHR SS - Shudder
Old Feb 16, 2020 | 05:45 PM
dougcjohn's Avatar
09 HHR SS - Shudder
The thread on SS Optional wheel had a few tangents...
https://www.chevyhhr.net/forums/gene...options-62801/
Regarding the Steering Wheel shudder discussion...
small update... I took the SS on a 4 hr drive this morning to combine a needed errand and get acquainted drive.
Basically a 2 hr drive out & back on I-80, mostly cruised, but had a dozen or so hard acceleration bursts to experiment.
Compared to my 2LT 2.4L 5sp Panel... very impressive.
The Tranny and the 5 sp shifter extremely impressive compared to my 08 2LT Panel's shifter.
On shudder... basically gone now.
I did some normal braking and didn't notice the shudder... as I expected not.
Although, after driving the car a few hours... I did some hard firm braking.
The shudder has reduced by I'd say 95% percent... is almost not present.
I'll drive it a little more... it may just be a little stiff, and simply normal use might help.
If it's warmer, I might pull off the wheels and take a closer examination.
Old Feb 16, 2020 | 06:18 PM
It could be a little corrosion on the rotors, from sitting. It’s possible it’s going to wear off.
Old Feb 16, 2020 | 08:21 PM
In the meantime, look thru the rims to view the rotors & see if they look like they need (ed) getting cleaned up.
Old Feb 16, 2020 | 08:36 PM
How long had the SS been sitting before you bought it?
Old Feb 16, 2020 | 10:10 PM
dougcjohn's Avatar
I’m not sure, he indicated he drove it to Omaha (2 hr drive) at times to visit his Daughter; which indirectly kind of chaps me... don’t drive a car for sale. Increases mileage, chance for dings, etc. Although, he appeared to take good care of his inventory.
He purchased from a Dealer, from a trade-in... apparently he often gets the older nicer condition ones clearly worth more than common condition,
From what I see, the rotors & calipers look normal... not bad, puc material thickness.
Although, I’ve seen stiff calipers that looked fine until you pulled them off.
Took it on a short errand & drive this evening.
Still may be LCA’s, running it above 80-90mph... hitting road roughness, feels like tracking slightly shifts at times. Accelerating through turns, again can feel a little track change. That may be ball joints and stabilizer links & bushings too.
Old Feb 17, 2020 | 07:32 AM
It could be , some PO installed the wrong LCA’s or ball joints, even the 25 mm sway bar bushings , the SS takes 23 mm . Very possible.
best to inspect closely
fusser87
7
Mar 17, 2013 06:47 PM
Biznass
Dec 7, 2011 04:08 PM
Doctuh
Dec 31, 2010 01:43 PM
Nukin'
Jan 9, 2009 09:12 PM
daniagm
Aug 25, 2008 04:29 PM
