2006 Chevy HHR Transmission wont shift into overdrive
Old Sep 5, 2013 | 02:34 AM
Oh dear, first off, don't trust a Jiffy Lube oil change place to diagnose anything beyond whether the sky is blue and your wheels are round.
"he said it was some kinda sensor to do with changing the oil and he cleared it but other then that all other places code workers don't work."
That's bull to put it mildly, check or have the fuse mentioned above checked, then head to your dealer or a good auto parts establishment to have the code/codes pulled when the CEL illuminates again.
I have a couple of ideas as to what's going on, but they are educated guesses only, we need more info to go on.
And returning to Snoopy's question, when was the transmission last serviced if ever?
Old Sep 5, 2013 | 12:53 PM
Decoteau's Avatar
Shift Solenoid A Control Circuit High
Old Sep 5, 2013 | 01:00 PM
???? and what about it? Was this the description from a code downloaded, or ???
I'm out of this one.
Old Sep 5, 2013 | 01:03 PM
Decoteau's Avatar
Shift Solenoid A Control Circuit High p0974 error code, is what he said he pulled
Old Sep 5, 2013 | 01:04 PM
Decoteau's Avatar
I have just got the vehicle I have no clue when it was last serviced
Old Sep 5, 2013 | 04:44 PM
Well I googled p0974 and found what seems to say, either the solenoid is bad, the wiring to the TCM/ECM is bad or the TCM/ECM is bad.
I did not spend a lot of time on it, but that's what I got out of 2 minutes.
Old Sep 5, 2013 | 05:18 PM
OK, that code helps a bunch, give this thread a read Decoteau, but I believe a trip to a transmission repair facility is probably in order.
Just click the link below.....
https://www.chevyhhr.net/forums/show...5161&styleid=3
Because of the lack of a known history on the vehicle in regards to mechanical maintenance, you could start with a simple fluid and filter change to see if that improves the transmission performance.
slowson88
Nov 26, 2023 10:03 AM
sklute
May 17, 2015 02:27 PM
tpaul
Jan 22, 2014 10:10 AM
johncin13
Nov 26, 2010 06:24 PM
