2006 HHR Climate control Worked One day and Nothing the Next Day Wondering
08 hhr ls sorry. Thanks for the help. I appreciate it. So I have taken the dash panel apart and cleaned the grounds that are on the side. And still doesn't work. I don't recall hitting a bump. At first it was flickering then about 10 days later it was all the way out. Thanks guys
Flickering kind of says : loose or corroded connection.
The only common link seems to be the ground wire, but could be a short in one of the components that does not work (maybe the clockspring). 2006/2008 should not make much difference in wiring; some wire color and pin positions changed that's about all.
