Door Latch
Old Feb 29, 2016 | 11:59 AM
fastsuv's Avatar
Door Latch
The driver's door won't open on our 2006 HHR 1LT, either from the outside or inside.
Using the search shows that it's probably the door latch that has failed. As I understand it, the HHRs use an "integrated door latch" which also contains the power lock actuator.
I went to rock auto to order a replacement, but they only show one for the right front door and the two rear doors. A check of NAPA online shows the same thing. What is going on? My factory service manual shows the same setup for all 4 doors. What am I missing here? Do I have to go to the dealer (or gmpartsdirect) for the driver's door latch? There are no aftermarket latches (Dorman, etc) for only the driver's door?
Steve
Old Feb 29, 2016 | 12:17 PM
Are the part numbers for the pass. side doors the same? I'm thinking the front and rear would most likely be the same.
Old Feb 29, 2016 | 01:37 PM
LATCH | Genuine GM | 20791793
20791792 - Genuine GM LOCK, Front Side Door
Chevy HHR Door Lock - Guaranteed Genuine
Must be left and right, the description doesn't differentiate
Old Mar 7, 2016 | 07:01 AM
fastsuv's Avatar
Thanks for the part numbers.
It's still strange that Rock Auto and others don't list the driver's side part.
My son says the door started working the next day and still works.
Of course, I fully expect the problem to rear its head again soon, so I will be prepared when it happens.
Steve
Old Mar 7, 2016 | 07:02 AM
Might need lube.
Old Mar 7, 2016 | 09:23 AM
prod's Avatar
The drivers door has the key lock so it may be more expensive.
Old Mar 7, 2016 | 11:14 AM
fastsuv's Avatar
Originally Posted by donbrew
Might need lube.
Good Idea.
I should open up the door while it still opens and see if there is anything obvious wrong and also lube it.
It'll be much harder to remove the inside door panel with the door stuck shut!
Steve
Old Mar 7, 2016 | 11:40 AM
Put some white lube on the outside part too. I had a rear door that was hard to open after the latch released; 1 dab of grease fixed it.
Old Jun 11, 2016 | 07:39 AM
scuba05477's Avatar
Question 2006 HHR LT door handle release cable
The cable snapped off where it connects to the handle and now I can't open the door from the inside. I've searched the internet and these forums but don't see anything about replacing the cable.
Anyone have any experience with this problem?
Thanks!
Old Jun 11, 2016 | 08:45 AM
Check here, the video in post #5
https://www.chevyhhr.net/forums/prob...-broken-43259/
arp
Jul 20, 2019 12:12 PM
Bowtiebandit24
Oct 25, 2012 09:08 AM
Leonard
May 29, 2012 10:34 AM
GriffingR
Dec 31, 2011 06:14 PM
pitbull76
Jan 25, 2009 04:38 PM
