2006 HHR Ignition Lock
Old Jul 29, 2013 | 02:42 PM
jer1041's Avatar
Question 2006 HHR Ignition Lock
Vehicle turns on/off no problem. However, I cannot get the key out until I reach inside a hole under the steering wheel and feel for a little lever. I manipulate the lever with one hand and I can remove the key with the other hand. I have noticed recalls on other HHR's regarding ignition switch problems, and also on the Cobalt. Any one know what I could do? There have been no stated recalls for my vehicle in this matter, as far as I can tell.
Old Jul 29, 2013 | 07:58 PM
If you would like I can check once again to see if any recalls have shown up for your vehicle. If so just private message me your name, address, vehicle identification number, and current mileage. Also have you taken it to your local dealership to have them diagnose the issue?
Thank you,
Jessica L.
Chevrolet Customer Care
Old Oct 2, 2013 | 11:44 AM
jer1041's Avatar
HHr ignition switch
Sorry, I didn't realize I had a reply to my query. I have taken it in to a local Chevrolet dealer. I explained to problem, they told me it was something in the transmission, which I find hard to believe, as I am able to manually (inside the steering column) locate the lever to trip in order to remove the key. They quoted me a cost of over $300.00 to fix. Seems a bit much for something I can easily remedy with a bit of ingenuity. I appreciate your response, and look forward to your help in this matter. Thank you.
Old Oct 2, 2013 | 11:56 AM
Actually, it is the transmission SHIFTER that is the problem. The interlock switch specifically, you may be able to take it apart and spray some WD40 or the like on it. The "official" repair is to replace the entire shifter.
Old Oct 2, 2013 | 01:32 PM
wmsburghhr's Avatar
Not sure if you have the same problem or not but look at this thd https://www.chevyhhr.net/forums/show...shifter+broken
HeavenlyHellRaiser
Mar 5, 2016 03:58 PM
metalhead52
Mar 23, 2014 06:06 PM
sbrice54
Aug 21, 2013 09:31 AM
johngpeg
Jul 29, 2011 03:25 PM
richie6
Jan 13, 2009 10:34 AM
