2006 hhr p0036 & p0300
Old Jan 16, 2020 | 10:40 PM
Originally Posted by donbrew
Is that a picture of the old O2 sensor? It should be gray/blue dry clean. You are burning tons of oil you Cat is getting trashed .And all the attendant problems.
He said the cat is deleted, so...
Old Jan 17, 2020 | 08:43 AM
mobilebyrd's Avatar
Yes. It is the old O2 sensor with 145K miles on it.
Thus far, I've never had to add oil between oil changes so I don't know how much it's burning.
What would you suggest I look at for the rough idle?
Old Jan 17, 2020 | 08:51 AM
Actually the 41-105 are the correct plug for the 2006 2.2
Old Jan 17, 2020 | 09:40 AM
Yep, there's that "2006 2.2" one-off factor again. Learn something every day... You stop learning, you stop living...
Old Jan 17, 2020 | 09:41 AM
Have you performed a compression test yet?
Old Jan 17, 2020 | 10:28 AM
  #26
It may show the 41-105 as the plug for the 2006 2.2 but it also shows the 41-103 as a fit also.
Think it's a case of "it fits".
Or one of those "it fits" like the LCA listings on most of the sites that say "fits all". Probably nothing wrong with using the 41-105's. Just a slightly different heat range of plug I'm guessing.
Old Jan 17, 2020 | 01:37 PM
  #27
Oh they fit and work fine, the 41-105 were also the recommended plug for Sweetie’s old 2003 Sunfire GT 2.2, which GM said all came with a 2.4 .
I don’t see the 103’s on this 2.2 listing on RockAuto
https://www.rockauto.com/en/catalog/...park+plug,7212
but they are listed for the 2006 2.4
Old Jan 17, 2020 | 02:00 PM
  #28
mobilebyrd's Avatar
Major DOH! moment.
I noticed 5 boxes of spark plugs in the garage...they were for the HHR.
I must have forgotten to replace them during the last major service.
She idles smooth after replacing the plugs...no misfires yet🤞.
Now, I just have to recheck the exhaust bolts to, hopefully, get rid of the fumes in the car. I torqued them to 34 #/ft.
Old Jan 17, 2020 | 02:16 PM
  #29
Manifold to head are 89 lb inch, studs to down pipe 37 ft lbs
https://www.chevyhhr.net/forums/how-...e-items-54648/
Old Jan 30, 2020 | 03:55 PM
  #30
mobilebyrd's Avatar
Well, P0420 bank 1 popped up and I'm getting a random misfire only at idle. I replaced the bank 1 sensor with a new denso unit just in case. I cleared the codes, and the p0420 Bank 1 and random misfire at idle both continued. I'll re-clean the MAF, TB, and see if that helps.
Do y'all also feel the p0420 is because the cat was gutted?
Figured I would ask here for most likely other causes of the random misfire only at idle. If I hold the throttle at around 950 RPM or greater the misfire disappears. The misfire is very sporadic. I'm thinking vacuum leak, but welcome more experienced input.
Last edited by mobilebyrd; Jan 30, 2020 at 04:09 PM. Reason: auto-correct victimization
