2006 hhr p0036 & p0300
Old Mar 18, 2020 | 06:07 PM
  #61
mobilebyrd's Avatar
Originally Posted by Oldblue
compression seems ok, plugs look good, take a picture of the butterfly plate in the throttle body, is it clean.
I removed and cleaned the TB and replaced the gasket just in case.
I also checked the air filter and it's good to good (gtg).
Old Mar 18, 2020 | 06:08 PM
  #62
Sparkling clean, y’all didn’t move the butterfly plate manually did you?
Old Mar 18, 2020 | 06:14 PM
  #63
mobilebyrd's Avatar
Not since the rag incident months ago.
Is it possible for a bad fuel rail to cause an issue? Fuel cleaner makes it run smoother and it was running really rough until I checked the fuel pressure at the rail and it started using better afterwards.
Old Mar 18, 2020 | 06:15 PM
  #64
You can remove the fuel rail and clean it out.
Old Mar 24, 2020 | 06:23 PM
  #65
mobilebyrd's Avatar
The engine still shutters once warm.
When cold, it seems to run very smooth.
Thoughts?
I rechecked the fuel pressure at the rail.
With the key left in the accessory position and the engine of the pressure went from ~58 PSI to 40 PSI in 30 seconds.
It was 60 PSI at idle, dropped to 56 PSI the moment the key was disconnected and had dropped to 54 PSI 1-minute after the key was removed from the ignition. Is this normal? The ACDelco fuel pump only has ~1K miles on it.
Old Mar 24, 2020 | 06:44 PM
  #66
That sounds close to right. It is supposed to be measured key ON engine OFF with pump commanded on (with a Tech2). 50-60 PSI.
Turn pump off
Allowed to lose 5PSI in 1 minute. Then reduce to 10 PSI then allowed to fall 2 PSI in 5 minutes.
The fuel pump only runs for 2 seconds engine off.
rbunton
Aug 27, 2019 07:24 PM
Oldblue
2.2L Performance Tech
25
Jul 19, 2018 11:47 AM
BDR1973
Aug 8, 2016 08:40 AM
Branjo
Maintenance and Upkeep
21
Jun 25, 2016 03:54 AM
jdcowboy
Sep 8, 2014 05:16 PM
