Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
I pulled the waterfall and removed the climate control module. To my eye, everything looks very clean. I don't see anything melting or looking burnt. But, should there be only 7 terminals in the center connector? or should there be 8? ADDED: I looked at used ones on ebay and they all have 7 pins.
In 15 years of owning and working on HHRs I have found many times those 4 bolts loosen up and cause problems. I don’t think that tightening them cures everything, I know it’s a good practice to check them as a process of elimination. Do the basics first!
One thing is for sure it only takes a few minutes to do.
