2007 HHR climate control issues
Old Jan 23, 2025 | 10:49 AM
These four, seven mm bolts
Old Jan 23, 2025 | 01:36 PM
JohnC_Sea's Avatar
Thank you.
Old Jan 23, 2025 | 01:40 PM
You are welcome.
Old Jan 23, 2025 | 03:22 PM
JohnC_Sea's Avatar
All bolts in the under-hood fuse box are tight.
I pulled the waterfall and removed the climate control module. To my eye, everything looks very clean. I don't see anything melting or looking burnt. But, should there be only 7 terminals in the center connector? or should there be 8? ADDED: I looked at used ones on ebay and they all have 7 pins.
Thanks!
John
Old Jan 23, 2025 | 03:50 PM
How many wires on the connector. Are 8 spaces populated? There are 2 spaces listed as "not used"
The items you cite are on all 3 connectors.
Old Jan 23, 2025 | 04:28 PM
JohnC_Sea's Avatar
Six wires...
I plugged everything back in and tested. All working correctly. So am putting the waterfall back together...
Done! And all still working. I will report back if it fails again.
Thanks for all the guidance. Much appreciated..
John
Old Jan 24, 2025 | 01:40 PM
greg8453's Avatar
Originally Posted by JohnC_Sea
Which four bolts.
Thanks!
John
It's the 4 bolts that hold the fuse block together. These guys think that cures everything.
Old Jan 24, 2025 | 01:58 PM
Not everything, just multiple seemingly unrelated electrical problems.
Old Jan 24, 2025 | 02:45 PM
In 15 years of owning and working on HHRs I have found many times those 4 bolts loosen up and cause problems. I don’t think that tightening them cures everything, I know it’s a good practice to check them as a process of elimination. Do the basics first!
Old Jan 25, 2025 | 06:38 PM
greg8453's Avatar
One thing is for sure it only takes a few minutes to do.
honeyman
Jan 4, 2022 05:09 PM
Bigjaycass
Feb 16, 2021 09:59 AM
jc102
Feb 15, 2018 09:41 AM
C-Meth
Jan 21, 2015 10:13 PM
rager24
May 12, 2014 08:40 AM
